Creo2 Patterns don't build in Creo3?
dprieb
It seems the enhanced Creo 3 pattern tool does not build Creo 2 patterns.  I am trying to migrate a parametric model template to Creo3 and have around 240 patterns in the templates that are ALL driven by parameters and they do not build in the new version. I have to delete and replace then modify the equations for each pattern.
All 240 patterns are axial in nature with parameters for [Number of instances] and [separation angle].
Is there a better way to do this?
7 REPLIES 7
DeanLong
(To:dprieb)
If that is true...Ouch!
David,
can you upload some example model ?
MH
Martin Hanák
dprieb
(To:MartinHanak)
I prefer not to share the model but see the pictures below. I built this model from scratch in Creo 2 and it works for any number of pattern members based on the 'teeth' parameter. When I turn the lobes on everything regenerates beautifully. In Creo 3 the former pattern leader builds every time but if I set pattern members to more than 1 I have regeneration failures or it builds the wrong thing. The other instances fail and I can manually enter a value for the rotation angle in the relation and it has no effect.
I think I will be contacting PTC support.
unfortunatelly pictures do not show exactly what geometry you are patterning. If you must not upload test model then I cannot investigate the problem ... I am sorry.
MH
Martin Hanák
llehuu
(To:dprieb)
Is there anyone who have a motobike Drawing? I'm very appriciate that you send me a document.
StephenW
23-Emerald II
(To:llehuu)
Try grabcad.  GrabCAD - CAD library
llehuu
(To:dprieb)
Unfortunately Gradcad just have a solidwork modeling and don't have the dimension indetail . Anyway tks for your help
