在重新部署新的版本Creo3.0 M070后每次打开都有这个错误对话框
请教。。
18606279656
Hi Andy,
I did a search in the internal TS database, for the error message and found an article that suggested to set the config option afx_enabled to no. Please give this a try and see if it helps.
If you are unable to view the article, you can create an account here.
Amit
