Customised Table
LuciferBV
Customised Table
I have a customised table for fetching all parts all parts from model tree . But the error in the table is it does not display alphabetically / in order of the model tree. E.G:- it goes like 001,003,002. but I need it configured as in order. Can anyone help. Attached is the file.
Thanks in advance
7 REPLIES 7
mbonka
(To:LuciferBV)
Hello Bhagyesh Vashi
as far as l know: Default sort "parameter" in BOM tables is weight , if nothing has been specified in SORT BY.
How to specify SORT BY parameter?
1. Create desired BOM table
2. Go to REPEAT REGION - SORT REGIONS
3. Select desired BOM table
4. Select EDIT in pop-up menu
5. Text editor will open - here you can define SORT BY conditions
- you can speicfy more parameters
    - first row is primary parameter for sorting
    - second row is secondary parameter for sorting
    - etc.
    - if all parameters are missing, than Creo use weight for sorting
For examlpe:
&asm.mbr.pozice Forward
&asm.mbr.pro_mp_mass Forward
6. SORT BY possibilities
BACKWARD or FORWARD
Search more info abou SORT TABLE or SORT BY PARAMETER:
Hope it can helps
Milan Bonka
mslotty
(To:mbonka)
Is there any way you know of to do this at the format level?
When we start a new drawing, we would like the BOM to populate in order by part number.
It currently orders it by the "description"
It is a huge pain to need to organize it each time a drawing is made.
BenLoosli
23-Emerald II
(To:mslotty)
In your drawing template, set the sort order in the repeat region so it formats the way you want.
mslotty
(To:BenLoosli)
After I posted this I realized I was just not pressing enough buttons.
THank you!
mbonka
(To:mslotty)
Mark correct answer if you question has been answered ...  else add another question
Milan Bonka
mslotty
(To:mbonka)
this is not my thread, so I cannot.
my tip...
1.]
Start with simple repeat region ... 1 column containin asm.mbr.name
Is component order equal to model tree ? I hope so.
Check repeat region attributes setting.
2.]
Go back to your table.
Check repeat region attributes setting. Try to set it as in 1.]
MH
Martin Hanák
