Hi
Would someone know how to make a set-up for cylindrical grinding in manufacturing module?
Is this mill-turn? The rotation axis of cutting tool is parallel to axis of workpiece.. Thanks for clues!
Currently using turn operation having turning tool instead grinding wheel.
Bob
As long as the current setup is giving you the correct program I don't see anything wrong using a turning operation.
If you want/need to use a milling operation, you may consider the grinding wheel as a side-milling tool
