As soon as I add "DEFAULT_CALLOUT_FORMAT_DATA" to the ISO.hol file, Creo 5.0.6 does not open that file and is not visible in hole dialog. I do not add anything else. Anyone knows why this is happening?
did you read http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/part_modeling/part_modeling/part_nine_sub/Formatting_Thread_Notes.html page ?
Please upload your ISO.hol file.
Hi Martin.
Yes, I did. And everything started from there. I made file like what it says in mentioned link but I got into problem hol_1 file not showing up. At first, I though because I use Notepad++ and CR = Carriage Return and LF = Line Feed and how Creo reads text file (in this case hol file) is where the problem lies, but it is not.
Then I realised that as soon as I add DEFAULT_CALLOUT_FORMAT_DATA Creo does not show it in hole dialog. I did the same for ISO.hol and same happened.
I'm not sure this is the issue, but in your sample file, the table that defines the callouts is missing.
The line DEFAULT_CALLOUT_FORMAT_DATA should be followed by callout specifications.
You can specify a different callout depending on hole configuration.
Can you load in the hole table if you modify your example ISO_1.hol and add these 2 lines:
HOLE_TYPE THREAD DRILLED_DEPTH THREAD_DEPTH CSINK CBORE EXIT_CSINK CALLOUT_FORMAT
TAPPED YES NA NA NO NO NO &DIAMETER[.3]
(also, I think reloading .hol files requires Creo restart)
I had the whole list below DEFAULT_CALLOUT_FORMAT_DATA and that's where issue started. Then, I put only DEFAULT_CALLOUT_FORMAT_DATA to test it and issue was there. I wasted 5 hours to solve this issue to no available. I was restarting Creo everytime. I attached original file I made first.
Ok, I had another look.
I tried your file and it wasn't showing up on my lists either.
I thought it's maybe in your headers as they look different in my system. So I changed your header to this:
TABLE_DATA
PRO_VERSION 24
THREAD_NAME VAN_ISO
THREAD_SERIES VAN_ISO
CLASS H
TABLE_UNITS metric
DEPTH_RATIO 1.25
CALLOUT_FORMAT CALLOUT NOT DEFINED - EXAMINE FILE VAN_ISO.HOL
THREAD_DATA
This still didn't work.
So I looked at your DEFAULT_CALLOUT_FORMAT_DATA table again and erased the whole thing and "cleaned up" the first line:
TAPPED YES VAR VAR NO NO NO &PATTERN_NO{0:X} &FASTENER_ID x &THREAD <CTRL-a>x<CTRL-b> &THREAD_DEPTH / TAP DRILL &DRILL_DEPTH
Note that data is lined up to the header row using spaces (no tabs)
This 2nd change made it show up.
Thank you for the help. I will try to do like you proposed now. But I remember aligning everything ...
It works now. Thank you all for the help! I attached working file. I guess THREAD_SERIES and CLASS must have hole file name, in this case it is ISO100.
