DRAWING TEMPLATES & PAREMETRS TABLES
ggarcia
8-Gravel
Hola, muy buenas tardes a todos.
Necesito saber cual es la forma de insertar una imagen predeterminada en un plantilla de plano (Template)
Tengo esto pero no funciona: {0:&sym(C:\USERS\JGARCIA\DOCUMENTS\SCA\EMPRESAS\CDI\LOGOS\LOGO)}
Hello. Good evening for all.
I need know which be form for insert a predeterminate image in drawing template.
I have this, but not working: {0:&sym(C:\USERS\JGARCIA\DOCUMENTS\SCA\EMPRESAS\CDI\LOGOS\LOGO)}
  • place your symbol (logo.sym) into the template
  • remove your symbol from template, the symbol definition will remain in the template
  • enter the note ... &sym(logo)
Martin Hanak
Martin Hanák
Martin Hanak
Martin Hanák
Dale_Rosema
(To:MartinHanak)
MartinHanak
Does this work for tables too?
Yes, it works.
Martin Hanák
Hello Mr Martin.
thanks for your fast answer...
Now, I remember I should convert JPG image to vector.
I 'll ask my costumer that convert the image.
Thanks for all.
TomU
(To:ggarcia)
Martin has the correct answer. The symbol must first exist in the drawing (template) in order to be referenced by a note or in a table cell.
