im using wildfire 4. im used to cross section arrows on backside of the arrows (pic 1). that the letter stays put and only moves in relation to the overall movement of the xsec arrows as a whole.
in whatever start file im using now... it places the arrows in front of the arrows... and then in addition if you adjust the leg length of the arrows if moves in relation to that length... so even if you manually move them behind the line... if you adjust the arrow leg lenths, the letters move in relation to the arrows... is this a drawing option... i cant find it.... help me out. i want it to be like the way im used to.
Nevermind. i found it in the drawing options. somehow missed it the first time.
Jeremiah, could you please share what option you found?
