When starting a new drawing the datum planes default to DTM1,DTM2 and DTM3. Is there a way to change the datum plane names to Right, Top and Front so that they always are Right, Top and Front when you start a new drawing? Are there standard parameters that you can modify or do you have to rename them every time you start a new drawing??
My suggestion would be to create a file with all the setting that are in line with your standards and then save that file with a name such as startpart (or something similar). Then when you create new parts, you open that part and do a "save as" to the new name and all your standards will be set in the new part. You may want to either lock or have a back up copy of the start file incase someone makes changes accidentally.
Thanks, Dale
Thanks, Dale
Hi Doug,
further to Dale's reply, there are config.pro options to help achieve your goal. They are template_solidpart & template_designasm. Create a part in the normal way, rename your datum planes & save it to, let's say Start Part directory. Now simply add the template_solidpart option to your config.pro file & browse to that directory. Now every time you create a new part you will have your default planes already renamed. You can also have the same for assemblies using template_designasm. There is also another config option, start_model_dir, which i think allows for multiple start parts.
John
