Datum Target Baloon Size
pdiletti-2
11-Garnet
Hi
I have this problem with CREO 2.
Using Draft Datum / Draft Datum Target / Box
The baloon created for Datum Point visualization is small for text.
The two drawing options
min_baloon_radius and
max_baloon_radius
set to ZERO don't work .
Any idea ?
Thanks a lot
Pier
7 REPLIES 7
StephenW
23-Emerald II
(To:pdiletti-2)
Since it's a symbol, I don't believe there is a simple solution.
I think the only solution is to create your own custom symbol that is sized appropriately.
Thank you Stephen
Please consider that this symbol is created automatically when you define a Standard System Datum Target.
If you use the BOX option and select a dimension, the text will be larger than baloon.
I'd like to avoid to use my own symbol in manual way !
Bye
Pier
being inch based, I have my .dtl options for these as:
max_balloon_radius .2
min_balloon_radius .2
I also have some other settings:
model_grid_balloon_display NO
model_grid_balloon_size .625
fyi
Thank you
but also modifying these options
the final diameter of symbol doesn't change
and the text is outside the symbol !
Pier
I guess that default symbol is designed with fixed size and is intended for short texts, such as A,B,...
Please ask PTC Support, whether you can configure symbol size.
MH
Martin Hanák
I officially asked to PTC support and , by now, there is not reply ...
So they are evaluating my topic .
Bye
Pier
The Baloon Size can't be modified
and, if the text is longer than baloon ,
it must be placed outside the baloon according to ASME 14.5M 2009 (section 3.3.3).
But the PTC symbol doesn't support this condition.
At the moment , if necessary, you must create a new customized symbol.
Bye
Pier
