Good morning everyone.
I have done this so many times, but this one is stumping me. I have a cast part model with all datums set and visible on the drawing. I am now working on the machined part models, by using Insert>Shared Data>Merge from other model. Once the dialog box pops up, I set the part to default, copy datums, and make it dependant. The part appears and shows up, but the my Y and Z datum axis does not. When I go to the layer tree and look at them, theysay CURVE id (feature #) not found in part (my machined part number). I followed these same steps in a model and merge yesterday and it worked fine. But I need these two datums to show up, so I can complete my drawings. Any ideas or suggestions?
I am using WF2 M240
Thanks in advance.
Jason
