Datum tag in generic part (family table)
sundoopi
Hello everyone,
I used family table to create two parts. In the generic part datum A was created on a plane. But this plane (feature) is suppressed in the instance part, so one error occored. But the change and this datum A is needed in the instance part. Could you please tell me how to do it with MBD? Thanks in advance.
Br
Sun
Well, I "faked it" by attaching the datum tag to a surface:
Generic:
instance:
This construction fill surface was then hidden away.  You should also add some relations so it follows the relevant feature sizes.
9 REPLIES 9
21-Topaz II
(To:sundoopi)
The Creo error with the annotation is resolved in this model for the generic and the instance. The annotation plane A is present in the instance without error.I have questions  about documenting a plane on a part that can not be established on the part for inspection but I suppose that is a separate issue.
You have to redefine the plane you are using for Datum A so it is not suppressed in the instance. This kind of thing happens a lot with section views, etc. You have to be careful when defining features to avoid using references that will be suppressed in instances from a family table. Check your references and replace them.
21-Topaz II
(To:sundoopi)
This would be an option to establish a datum reference plane in the context of your family table.
sundoopi
(To:tbraxton)
Hello  tbraxton,
yes, you are right. But this option is not suitable for our part.
But thanks too.
Br
Sun
Patriot_1776
(To:sundoopi)
This is one of the MANY reasons why I do not use MBD at ALL, and put ALL my GD&T info on the dwg.  This way I can easily change anything I want, and not affect anything else.  Also, this eliminates having problems with duplicate datum names at both the part and assembly level (as for a weldment, etc.).
@sundoopi , are you trying to accomplish this:
generic:
instance:
sundoopi
(To:pausob)
yes!
Generic:
instance:
sundoopi
(To:sundoopi)
Hello all,
thanks for your answers. It looks, that we have to trick the message center with a "faked datum plane".
I found in Creo 6 or higher versions we can have a besser solution:
(952) Improved Handling Between Parent and Child for Annotations in Model-Based Definition | Creo 6.0 - YouTube
Best regards
Sun
