Decals not saved
ayaqoob
Decals not saved
Hi, I know that how to save decals within my own system i.e to place them with in default place for decals but when i export to any other format, only the colors of materials are saved without any decals. Is there anyway i can save decals to an exported files? or if i could modify .mtl file permanently so that decals get saved with that?
I think Creo is not able to put decals into export file formats. For example see https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS177590.
You can ask PTC Support ...
MH
save_texture_with_model yes
also see the other save_* options
Also in the render dialog.
Well, i have already set save_ options to yes. Does not work, only the material color is save not the texture. Tried various formats too.
dschenken
(To:ayaqoob)
The problem with anything except color is the receiving system must have a matching method of projecting the bitmap onto the surface(s).
Looks like you are not the only one to look for an answer:
graphics - How to export textures? - Mathematica Stack Exchange
I expect that the most frequent use is .stl/.vrml but those are triangle mesh models that have well defined uv coordinates for each face to map a bitmap with.
Not sure about the .mtl file - this seems to cover it well http://www.fileformat.info/format/material/
I dont use Mathematica. I have tried all those formats.
MH
Thanks, i needed a confirmation, tried almost everything.
