Default model/scale for a drw sheet
GavinBRumble
When you create a new sheet in a multi-sheet drawing the sheet gets a
default model and scale.I can't figure out how to find out what the default
model is. You can't look for answers in the Format parameters because if
you replace the Format, then the Format parameters get tied to the currently
active model which can be different from the "sheet" default model. The
reason for this question is, in a drawing of a weldment (assy) with several
part models added, the Default Scale for Sheet option that shows in the View
property dialog box will display this "sheet default scale" which can be
(and in this case is) different from both Titleblock scale and the scale in
the drawing mode status area at the bottom of the screen.
Using WF4.
Thanks in advance,
Gavin B. Rumble, PE
Solid Engineering
336-224-2312
0 REPLIES 0
