I have looked all over for an answer for this, but I have yet to find an answer.
Is there a way for me to make a file (.PAT) which CREO reads on opening, so that when a cut section is made only predefined hatch patters are used in the drawing? This is with regards to assembly drawings btw.
I have figured out how to make a .PAT file from which I can choose predefined patterns, but I have not been able to define the file as the default directory.
I am currently in CREO 4.0 and we do not used material selection in PTC CREO. So it will not work to assign different hatches to different materials.
Thank you for any reply.
Hello @KH_5248782
This pre-configuration is unfortunately not part of current Creo Parametric capabilities. What is possible to frive as a default is:
There is however no config option allowing to get a default selection of what is configured in the Edit Hatching User Iinterface (accessed whil defining/redefining a cross section). This limitation applies therefore:
Considering above, we may only suggest eventual creation of a mapkey which will proceed as follows:
Serge
Hello @KH_5248782
Serge
