Hello Creo Community members,
I am currently working on parametric model. This model changes according to relations and thus, we can create multiple variants. Now, I need to solve problems with purple (not regenerated) dimensions which appear on drawing when I change between different variants.
I used drawing program to create combinate states to control purple linear dimensions. But this is not working for ordinate dimensions, which I need to use.
I used all model dimension in the drawing that I could to avoid regenerations issues...
Is there any way to remove all the purple dimensions at the same time, so that the model user doesn't waste time removing them one by one ?
Thanks in advance for your contribution
Peter
