I am working on updating our company mapkeys in Creo 2. In several of them I add the command Deselect All at the end.
How in the world do you deselect all on a drawing. I can type in "deselect all' in the command search but it doesn't display the location.
As a work-around I can select the Activate button and that will deselect all objects.
I see it in the Customize Ribbon area but you can only add it to a Tab or Group you create. Is the Deselect All icon not displayed by default?
Steve G
Hi Steve.
Try this: Select a few objects and check the bottom right corner of the Creo window. You'll find a text "xx selected". You can right click on that text and in a context menu select "Clear". I guess that should work for you.
HTH
Matthias.
Sorry. I meant the other Clear tip from Matthias.
Steve G
Hi folks.
Forgot to mention: Try double clicking the "xx selected" - you'll get a list of the selected objects with the option to remove single elements...
Matthias.
