Could you please share your experience?
Revision Scenarios | |
1 | Terminal Change (Qty 4) |
2 | Length Change |
3 | Connector Change (2 x 4Pins) |
4 | Connection Change (6 Wires) |
5 | Tape removal (Qty 2) |
6 | Tape addition (Qty 2) |
7 | Notes Change |
8 | Wire Color Change (Qty 😎 |
9 | Wire Guage/Style Change (Qty 😎 |
10 | Splice Change (Qty 1) |
11 | Diode/Fuse Add |
12 | Grommet/Clip Change (Qty 1) |
13 | Grommet/Clip Reorientation (Qty 1) |
14 | Wire Branch deletion |
15 | Wire Branch modification (one branch out location to other branch out location |
16 | Connector cross section view change |
17 | Ferrite coil length change (changing from x number of turns to y number of turns) |
For above scenarios how much your organization takes to revise any design for above mentioned scenarios?
Product | Steps | High | Medium | Low |
Creo Schemetics | Wiring Diagram | |||
Report table | ||||
XML | ||||
Procable | Simplified rep of Master Assy. w.r.t. wiring assembly | |||
Harness Component Placement in Model | ||||
Creation of Skeleton model & shrink wrap (extracting surfaces of simplified rep) | ||||
Co-ordinate System creation | ||||
Assembling harness parts (Skeleton model) | ||||
Importing XML | ||||
Network path creation | ||||
Autorouting of wires | ||||
Family instance creation | ||||
Flattening of Harness | ||||
Drawing creation with BOM Table, Cut sheet, Spool table, Connector view | ||||
Check-in / Check out in Windchill | ||||
Promotion request process in Windchill |
