Dimension settings defaults
jcolon
3-Visitor
When I place a dimension it is 3 places, I can go into properties and change it to 2 places, but I have to do this to each and every dimension.
Is there an doption to change the default from 3 places to 2 places so that when I create a ne one it comes in as 2?
In addidion, can I make it so that my dimensions come in as fractions?
I am hoping it is an option in the .dtl (drawing properties) or in the config.pro (configuration editor) file.
StephenW
(To:jcolon)
Also try the config.pro option
create_fraction_dim YES
BenLoosli
(To:jcolon)
default_dec_places in config.pro can control the number of decimal places for a dimension.
deafult_dec_places 2
DTL file setting dim_fraction_format will control how dimensions use fractions.
I found the decimal place option in the config.pro file (Thanks, it was an option that didn't show up until I changed the value).
But the fraction setting doesn't seem to do anything in the .dtl file.
I have picked the std and the aisc options (as well as default) and nothing seems to change with either option.
StephenW
(To:jcolon)
jcolon
3-Visitor
(To:StephenW)
This did it. Thanks!
Dale_Rosema
(To:jcolon)
Don't forget to mark Stephen's answer as correct.
