Good afternoon everyone. I think I have an easy question for some of you. As for me.....it's driving me insane. The picture I attached shows my problem. How do I make the Draft Datum Target balloon adjust to the text in the top half of the balloon? This is the symbol that came with Pro-E. But I just can't seem to make my diameter dimension fit inside. Any help would be greatly appreciated.
Hi
this post is very old but now I have the same problem with CREO 2.
Using Draft Datum / Draft Datum Target / Box
The baloon created for Datum Point visualization is small for text.
The drawing options
min_baloon_radius and max_baloon_radius set to ZERO
don't work .
Any idea ?
Thanks a lot
Pier
