Does anyone have a technique for creating a drawing BOM table that displays unique quantities for each simplified rep? It seems that BOM balloons are not supported with a table that references multiple simplified reps. I currently have configured a work-around using the region relations to drive a quantity for each configuration, but it requires manual configuration for entities that vary (example below). Is there any way to reference the simplified rep values in the relations?
qty1 = rpt_qtyif final_name == "COMPONENT_01"
qty2 = 5500elseif final_name == "COMPONENT_02"qty2 = "-"elseqty2 = rpt_qtyendifendif
I am using Wildfire 3 M160
Steve
