Drawing Tutorial: LAYER FOR DRAWINGS
KulbirSandhu
8-Gravel
In the large Assembly, when you need to simplify your drawing view, the layer technique is the best option to deal with component visibility. Find out more in the video. Hope you find it useful, I will look forward for your comments, Thanks.
Thank you so much. It's very useful.
@wsweathamal Happy to see, it helped you in some way. 😊.
