Using Creo 8.0.9
I'm working on a drawing that has a large table of dimensional values that directly reference dimensions created on views in a later sheet. When I create the dimensions on the drawing view, I enter a symbolic name (like 'H4', see image below) that corresponds with the name of the value on the first page. This way if the model changes in the future, the table automatically updates instead of needing to manually type in the new value. So, the table on sheet one has the value &H4, but displays the dimension named 'H4'.
The issue I'm running into is that sometimes when I enter the name I want, it brings up a pop-up that says "This symbol is reserved or exists already". When I look through the annotations dropdown in the drawing tree, the dimension name I want isn't found under any of the views so there shouldn't be a conflict.
Is there a way to see a list of all created dimensions on a drawing? I've also tried looking in "Show Model Annotations", but don't see the names I want there either. Is it possible there are hidden dimensions somewhere that I'm not looking, or is this a bug?
Thanks for any help you can provide!
One possible cause is that a drawing user (using create_drawing_dims_only no) made a driven dimension in drawing mode that lives in the solid model, and named it using the name you are attempting to use. If this is the issue, then when in drawing mode you should be able to find the driven dim with the name in question.
That would make sense. In response to your below comment, I don't think it's a naming issue, as it works sometimes in other drawings with the same symbolic name.
How do I access drawing mode within an assembly? I'm not familiar with anything but the standard 2D drawing in Creo. Is there an advantage to this over a regular drawing?
When you have a 2D drawing as the active window in Creo Parametric, that is drawing mode.
If you are using an assembly as the model to create a drawing if any of the parts/components within the assembly may use the parameter name, then that could be an issue causing the error. I am not positive about that, but it conceivably could be an issue in the context of a drawing. If you have a dimension named "H4" in more than one part/component in an assembly then when you try to assign that name to a new dimension, it could be a problem.
I am using an assembly to create the drawing, but all the components in the assembly are skeleton models with shrink-wrapped geometry, so there are no other parts or components that have drawings that are directly linked to this assembly. We also don't tend to give names to dimensions in drawings (this assembly being the exception, so it's not likely that there's something with the same name in another part connected to it.
Hi @MK_12698627,
Anurag
This is a list from PTC but without a declaration that it is inclusive of all reserved names.
