Hii!!
I want to create drawing templates using 1st angle projection method. I tried to make the templates but the views are not in alignment. How can I align them?
I am using creo parametric 3.0.
hi, there
draw a line first, then click template view. after you insert the general view, you can double click it to choose edit-placement by vertex. so that you can move the template views to the vertex. you will get views aligned.
Good luck.
Claude
hi, there
Good luck.
Claude
Thank you for your response!!
