Drawing viewed with Creo View doesn't match drawing in Creo Parametric
sbrown-3
I created a drawing in Creo Parametric (2.0) with 6 sheets, thus multiple views. When I view the drawing in Creo View there are 3 dimensions that are flipped from the right side of the view to the left side of the view and are overlapping other dimensions. I can print a PDF out of Creo Parametric and the view is fine. Any ideas on how to fix this Creo View problem?
please ask PTC Support.
Martin Hanák
Check if your representation is publishing "As Stored" or "Latest".
If it is latest then whenever the model is changed, the representation is updated.
