Hello;
I'm a SW user who occasionally gets asked to output dxf's as cgm file, & we have Creo so I can do it within that. I inserted the data from the
dxf into a drawing, & if I say fit, everything comes in different scales, however if I say don't fit to scale, it comes in proportionally but not within the
format area. How do I move it within the format area?
Thanks;
Rob_D
When you open the DXF as a drawing, it takes on the value of the DXF file, including bounds.
When you import it, it give you a scale option.
These are now sketches entities. You can translate, rotate, scale, etc. the same as you would any drawing sketch.
Personally, I prefer to open the DXF file as a model. Then I can make a drawing using a view of the 2D model.
I can also manage origin locations if there is a reference available.
I also export DXF from drawings with "formats" blanked.
