ECAD Keepout external references missing when adjacent part changes
vloos
1-Visitor
I have a PCB, created in ECAD, which I created keepouts in.
The keepouts were created from external references from an adjacent part
(offset use edge lines).
When that adjacent part is modified all the keepouts fail due to missing
references. Some references no longer exist as the external part has
changed, but most are still there in their original positions.
When I try to replace the references a few replace OK, but most cause
Pro-e to abruptly exit.
I can, of course, delete all the references and redo them all, but this
is quite an extensive keepout feature.
Anybody have any suggestions?
Vinson A. Loos
Mechanical Engineering
DRS Tactical Systems - Melbourne, FL
(321) 727-3672 Ext. 3409
- <">mailto:->
www.drs.com <">http://www.drs.com>
NOTICE: This e-mail transmission (and/or the attachments accompanying it) may contain confidential or proprietary information belonging to DRS Technologies or the sender. The information is only for the use of the intended recipient. If you are not the intended recipient you are hereby notified that any disclosure, copying, distribution or the taking of any action in reliance on the contents of this information is strictly prohibited. Any unauthorized interception of this transmission is illegal under the law. If you have received this transmission in error, please promptly notify the sender by reply e-mail, and then destroy all copies of the transmission.
"This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior written approval from the U.S. Department of State."
0 REPLIES 0
