Edit Definition, remove transparency
TA_10371075
2-Guest
hello, I know i was able to change this option in wildfire 4.0, however in creo how do you change it so that when you do edit definition the parts not being edited stay solid and not change transparent.?
kdirth
20-Turquoise
(To:TA_10371075)
I believe you are looking for Config Option - dim_inactive_components never
kdirth
20-Turquoise
(To:TA_10371075)
Thanks so much, that worked!!
