Editing Overriden Dimensions Text
Kevin76
6-Contributor
This has actually bothered me for quite some time, so hopefully I will get a good answer to resolve my dilemma. Occassionally I need to override dimensions, I hate to do it, but sometimes it's unavoidable. When I have a dual dimension, and I enter the text for the secondary dimension (in brackets) tolerance of +xxx/-xxx (PRO Code @++xxx@#@--xxx@#), the brackets are always normal text height, aren't big enough to encompass the tolerance and makes the overridden dimensions with +xxx/-xxx look different. This causes a problem when we use +xxx/-xxx tolerancing, because on the same drawing with shown or user defined dimensions, the brackets are big enough to encompass the tolerance. How can I edit the overridden dimension to appear the same as a shown or user defined dimension.
If it's a character, word or string of text. If you start the (say a letter) with this bracket { a number and : type your letter then close it with the }. example {1:(}@++2.0@#--1.0@#{2:)} Hit the enter to place it on the drawing. Now you can mouse over either of the brackets, select it only, and you can ajust the fount height or type of fount. I hope I'm answering your question? It just seamed like you were saying the super and subscripted were taller than the brackets and you want the brackets a larger fount, if I'm right this should help. Frank
Kevin76
6-Contributor
(To:FrankMcDougle)
Frank, thank you for your reply and interest in helping me, I greatly appreciate it. Unfortunately, this is an overridden dimension, and, at least from what I have seen so far, I can't get your suggestion to work. I will have to try it again when I revisit that drawing. I will reply to this thread again to verify if it worked or not.
