Here you go...
<u>Tip: To Make a ≥ or ≤ Symbol Within a Note:Format note as follows:
@#>@# OR @#<@#
In Reply to Lar Kerila:
Hello folks,
Happy new years.
Say, I found I could add a less/greater than or equal symbol to my drawing
by holding the ALT key and typing the ASCII code # 242 or 243. Great! Why
isn't this in the Pro/E symbol palette?
Now for the bummer: when I create a PDF file (straight from Pro) it
DOESN'T PRINT the symbol! WTF?
Any solutions, other than creating my own custom symbol?
Cheers,
-Lar
You're right, the entire line of text in the dimension changes. That sucks. Here is one workaround...not the best, but it does work.
Put your dimension in and place a single (or double) space between the left and right side of what your want your symbol to separate. Then place a free note in the blank space, put in your symbol and changethe font. Once the text is aligned properly, it willappear to be just a dimension.You can thengroup the text to an object & pick the dimension. If youhave to drag the dimension, the text will follow. I even moved the dimension from one view to another, and they still appeared okay.
Like I said, not the cleanest, but it does work.
Brian
Actually, Brian's method has a serious short coming. When I change the font style to Cal Greek, it always changes the style for the entire line of text (dimensions too). I don't want that, since it will force me to have to create a separate note in order to work around this limitation. Any other bright ideas?
For those that may be interested...
This method DOES work, as described, but depending on the method used to create the output document,the text can be messed up. Lar & I spent a little time troubleshooting, and we discovered that when the SaveAs PDF function in Pro/E is used, the output is messed up. If the Acrobat Distiller is used, though, it will print okay. Not everyone has the distiller, though. If you have access to the Acrobat Distiller, it is a quite reliable PDF creator.
There are also other PDF creation programs out therethat may avoid this issue, but I have not tried them. There are various suggested PDF creation programs in other threads within the forum.
Brian
This technique does NOT work for dimensions. I didn't try it with text. I've been using Pro/E for 20 years. Admittedly, this is the first time I've run across the need for equality symbols on a drawing. However, in this case it is a drawing for cosmetic inspection criteria. You'd think PTC would have the equality symbols built in to the symbol palette. PTC! PLEASE FIX THIS!!!
I agree with evreyone else. PTC please fix.
Every symbol should be available in the text symbol pallett. Microsoft uses allows you to use all symbols.
Isn't Creo-Pro "Microsoft compatible"?????
In Reply to Brian Kurth:
Brian
