Having trouble getting ModelCHECK to work in Batch mode. Any tips on how to resolve? I should note that I can get Interactive mode, with modified config files, to work with no issues within Pro|E.
I get the following errors in Batch mode.
From ModelCHECK - Summary Report
Cannot retrieve xxx.PRT
From ModelCHECK - Batch Summary Report
Error checking this model
From mc_err.log file
ERROR: Can't reset the SIGSUSPEND
I did use the provided PDFs while setting up my config files but I will take a second look at my config_init.mc, checks.mch and start.mcs files to see if there is something I failed to enable for Batch mode.
I've run into issues from time to time with spaces. Try to eliminate spaces in all the paths. Hope this helps.
