I'm currently taking the online training for Wildfire 5.0 and I was doing the rounds exercise were
you select 2 edges in a L -block that has a half-hole in it. The round is broken by the hole (select 2 edges). The exercise
says through Pieces tab in the dashboard I could chose which round feature is included or excluded.
When I use the pulldown I don't have exclude as a choice. Is this not supported in Ver 5.0?
Thanks Jim
Round and Select two face, you will find .
