Export from sketch
cjohansson-2
Export from sketch
I would like to export geometry lines from within a sketch to dxf.
That should be possible cause it´s a 2d geometry.
I can not find the export button.
Claes,
you want to export 2D geometry from Sketcher mode ?
Martin Hanak
Martin Hanák
Yes, you are right.
Claes,
unfortunatelly in Sketcher mode, the Save a Copy command does not enable to export section geometry into DXF format.
Martin Hanak
Martin Hanák
Not possible? In SolidWorks it is easy.
Well, then I need to find a workaround....
import to drawing..export drawing..and so on..
Create datum curve using the sketch.
Create drawing of datum curve.
Export.
