FLOW CONTROL VALVE
ptc-4237095
FLOW CONTROL VALVE
I need to model flow control valve in Creo 1.0. Please find attached IGES format of Flow control valve.
Can any body help me out in designing FLOW CONTROL VALVE in Pro E.
I tried to model but I am getting stucked in Blend Features option.
Finally, I am observing message as "Failed to generate"
I am really fed up with this particular design.
Please help me out with this.
Hi
Please Upload your Creo Part(with failed feature)
So that we can know exactly where you are facing problem?
K.Mahanta
