All
We have an assembly which before opening now asks a question regarding resetting family table values to their previous values? See the attachment.
The top level assembly is large...approx 2-3000 parts but it does not contain a family table so I suspect it is for some lower level component. There are some components within the assembly that have had their 'pro/program altered so as to prompt for new values of parameters. I guess this has something to do with it.
So just wondering has anybody else come across this unexpectedly? Any tips on identifying what family table it is referring to? Any idea how to stop the question appearing in the first place?
All help appreciated, thank you.
Neal
The only method that might work is "reference viewer". It is mostly use to find missing dependencies, models and ghost file references. It will detect current problems but i suspect your problem could be PDM windchill version files. are you using the latest version file
