Family table creation with instances on layout driven models
Rathish
Is it possible to create the Layout driven models into Family table (Generic and no.of Instances) at the same time. I have tried but when I try to add the family table parameter, the parameter relations are not visible in the window , hence the parameters are locked by layout.
Please suggest me any other alterntive method to resolve this issue.
Rathish
0 REPLIES 0
