The retrieval order change a few releases back, putting the directorythat the parent item (drawing or assy) ahead of the working directoryand the workspace. That TAN was created 11 years ago. Even though itwas updated in 2005, it doesn't seem like it's accurate. This TAN suggests a slightly different order:https://www.ptc.com/appserver/cs/view/solution.jsp?n=131190 This is an intentional change in Pro/ENGINEER Wildfire where thesearch order is as following: 1) Pro/ENGINEER session 2) the Search/Retrieve directory where the parent object wasfound 3) Active Intralink/Windchill Workspace and Commonspace 4) Local Working Directory 5) Search paths ...It would seem that the one you found is incorrect. Also, it adds: There is a hidden configuration option to do it the old way: "use_2001_search_order YES"Not sure if that option is still valid for WF3 or not.Doug Schaefer
LinkedIn
