Find drawing model referenced in note or table
LarsZiegler
Hello!
I have to find out which drawing model (more models in drawing) is used for the titleblock.
For example the cell of the format table contains &TITLE:2.
How can I find out, which model is referenced to that parameter?
Or how can I read the session ids of the models?
Thanks!
Greetings Lars
TomU
(To:LarsZiegler)
Drop the text from the attached text file into a note or table cell. This will show you the model name for each session ID active in the drawing. Just don't attempt to copy the note or table between drawings because after it's been evaluated once, any parameters not in session will lose their "&" parameter designator and simply become dead text lines.
Tom U.
LarsZiegler
(To:LarsZiegler)
Hello Tom!
Thanks for the answer.
I will do it like that!
I know the ID. Can get it from TITLE:2 and so I create a note with &model_name:2 and &type:2 and can read the modelname and type after that.
Greetings Lars
Here is my favorite way of dealing with this issue: Simply add the attached note to your drawing... (hint - save it to your Pro/E standards folder for future reference...)
