Flat Pattern Overlap Relief?
jtruitt
I'm currently making a quick design with two flanges that butt up to each other, however the flat pattern will have an overlap. My question is whether or not there is some option or method other than manually adding an extrude on the flat pattern with a sliver of material removed so allow the bend. Manually making cuts seems kind of strange, I'd think there is some method that considers the flat pattern to create the proper shape. Thanks.
0 REPLIES 0
