I have a complete machine assembly and I am now in Creo 3.0.
In the assembly view I can open up tree columns that I find useful as a global control of data to be added to fields.
I want to know if anyone has a command for the data field for the change over from ANSI to ISO standard.
Currently I have to open each file in turn and go thro sub menus:
PREPARE - MODEL PROPERTIES - TOLERANCE, this is very indirect, I want to access these from the top level Assembly.
Any help would be appreciated.
Francis
While not a complete solution, you could make a mapkey that sets the tolerance standard and closes the model. Then, you only have to open the model and run the mapkey. It is still cumbersome and annoying for larger assemblies, but it does take some of the clicks out.
