Generate fixed length tubes
aturcat
6-Contributor
I would like to know if it is possibled to generate a tube with a fixed length on Creoparametric2.0
Thank you for your response
Ambroise.
BenLoosli
23-Emerald II
(To:aturcat)
You can create a tube of any length.
If you mean a flexible tube that conforms to a spline or multiple curves, you can, but you have to build your base curve to be your desired length.
aturcat
6-Contributor
(To:BenLoosli)
Thank you for your answer
What I am looking for is a parameter that sets the length.
A flexible tube is exactly what it try to design, but I autoroute the wires after defining a network, and i think there is a way to tell "go from point A to B, with such length", is that possible?
Thank you
Ambroise
