Getting PRO_TK_PICK_ABOVE error on use of Proselect. Can any one explain why.
mwaghmode
I am using Proselect in loop to select the model in drawing. and i am getting PRO_TK_PICK_ABOVE error . Can any one explain why.
Manoj
From API header files description:
Return Values:
      PRO_TK_NO_ERROR   - The user made a selection, or chose <b>Done</b>.
      PRO_TK_USER_ABORT - The user chose <b>Quit</b>.
      PRO_TK_PICK_ABOVE - Selection was interrupted by a user's pick on
                          any button from above menus.
      PRO_TK_E_DEADLOCK - The Creo Parametric user interface is not prepared
                          to handle this request (because it is blocked by
                          another process such as an OLE container activation).
Alex
Thanks , but i want why the error is coming.
FV
17-Peridot
17-Peridot
(To:mwaghmode)
please check if you are using uiCmdPrioDefault instead of uiCmdPrioImmediate.
HIH.
Feliks.
Hello Manoj,
the user interrupts the selection by clicking on another function/menu and the error is returned by Creo to let your TK application know, so you can deal with this situation in your program.
Gunter
