Getting PRO_TK_PICK_ABOVE error on use of Proselect. Can any one explain why.
mwaghmode
I am using Proselect in loop to select the model in drawing. and i am getting PRO_TK_PICK_ABOVE error . Can any one explain why.
Manoj
0 REPLIES 0
