Goemetric tolerances in ASM
afontaine
Hello the community,
In Creo2, I would like use as reference a reference come from another part (see picture).
The purpose is to create a geometric tolerances annotations feature in the part Grey (link to the basic dimension 7.5) using a reference come from the part blue. It is really the need because the asm is an overmolding and the definition has to be embended in a drw of the asm.
The probleme is that I can not use a reference come from anther 3D model in the Geometric tolerance creation window.
Any idea ?
Many thanks
BR
Arnaud Fontaine
You can create a skeleton model with datum planes and use them as a reference to create the blue and gray part. By this you can use the references to create the GD&T in the drawing
afontaine
(To:Praveen)
Many thanks for your answer.
The blue part need also their own drawing, that the reason why I tested others solutions given by a colleague:
- Copy geometry of the datum in the gray part. Result: it seems to be impossible to use datum in the GD&T.
- Inheritance feature (with suppress of all solid feature, only keep needed datum). Result; Ok it is possible to select datum from the inheritance feature. See below.09-06-2015 11-15-26.jpg
At the end I can obtain 2 drawings using the same references which is the functional need:
- Gray part:
- Blue part:
If you find easier solutions, please write here.
Thank you
BR
Arnaud Fontaine
