I am having a problem with images that are inserted to surfaces of parts. After inserting an image, I saved the file close Pro-E completely. After re-opening Creo, the image disappears, but the part surface is still in its specified color. I thought it could be a file reference issue, but the image will disappear regardless of where the file is located.
Hello Jane
Place your source images for textured colors must be in the working directory (for one project).
Vladimir
Note: Place your images to: creo_dir\Common Files\M020\graphic-library\textures\
(for all yours projects).
