When drawing only the cursor shows on some of my computers and on others the object shows while drawing. How can I fix them to show the object and cursor?
Toben,
this is probably caused by graphics card driver. Check its version on your computers.
For testing purpose, you can temporarily add the following option at the end of config.pro file:
graphics win32_gdi
Martin Hanak
Toben,
I agree with Martin. This appears to be a graphics related issue.
I would also suggest taking a look at your machine configuration, on the Platform Support page, and verifying that you are using a certified or supported graphics card and the correct driver version.
On the Platform Support page, click on the By Product drop down and select your product, e.g. PTC Creo 2.0.
Amit
