Hi we using wildfire 5 creo elements, in the present scope of work we need to create 2 sheet in the drawing. where we are trying to copy the first sheet view and dimension to second sheet which is creating problem
nitagi
Hi
kindly help us to overcome this issues.
BenLoosli
(To:nitagi)
What sort of problems are you having?
If you have shown dimensions, they will not copy as that makes your part double-dimensioned.
what every views and dimension are present in the first sheet of the drawing, I want to copy them to second sheet, because I want both the sheet to took same
