HI
When the user isolate some component in the model tree, then when user select all components and Clikc unhide means, only the main level component is Became active, Still, the Nested components are in Hidden state
Please fix this bug
I fear that you are not in the correct community. Here you are in the community "Creo Elements Direct" that is a software different from Creo Parametric. You should move your post to the community "Creo Parametric" to have a better chance to get an answer.
Hi LN,
To solve this, you could customize your 'mini tool bar' adding the 'Unhide All' icon:
