I've created my first movable assembly in Pro E Creo 2.0. It's of a torso and leg with fully rotating hip joint. When I click on Drag Components and swing the leg, I can swing it everywhere including into and through the torso. Is there a way to have the leg stop and not "go into/through" the torso as if it really is solid?
Maybe Collision detection settings will help?
To switch on, see CS139196 : How to set collision detection settings as "Stop When Colliding" in Creo Parametric 2.0
