I am using Creo 11. I have separate .hol file. I want to write code in that .hol file so that "1 X" should not be visible in the hole note. Plz help, how can I modify this line
{0:&PATTERN_NO}× /{0:&FASTENER_ID} × {0:&THREAD_DEPTH[.1]}<ctrl-a>/<ctrl-b>{0:&DRILL_DEPTH[.1]}V
so that Pattern_No will not visible if the value is 1.
In your callouts, you should use the HOLE_INSTANCE_... tokens that only show up when multiple hole instances are in play.
See more in this page:
