How can I do Solid Parts If I have a Surface Part??
melias
3-Visitor
Hello There!!
I Have a PRT that is only surfaces, I would like to Know If are there a way to change IT to Solid PRT.
I have Added the file, and waiting that somebody to help me with this ISSUE.
ME
Mahesh_Sharma
22-Sapphire I
(To:melias)
Mauricio,
Another option here is repairing the geometry using IDD. With in IDD you can delete surface, create a new surface, fill the gap and close entities. These steps will not create any additional features in Model tree.
Check attached video for steps to correct geometry in one area.
7 REPLIES 7
DavorGranic
(To:melias)
Hi Mauricio,
Here is solid part(Creo3).
You first need to go to import doctor and fix-remove extra surfaces that are messed up then in part modeling add missing surfaces. Merge evrything and then solidify.
If you cant solidify some surface part there are mainly 2 reasons for it:
Quilt is not closed or surfaces are twisted/intersecting.
Thanl you So Much Sir!!!
ME
Mahesh_Sharma
22-Sapphire I
(To:melias)
Mauricio,
Thank U Mahesh, for the excelent video
ME
Sorry Mahesh but I dont Understand the proccess to fill the gap, I dont find the pop up that you show me in the video, could you explain me please??
ME
Mahesh_Sharma
22-Sapphire I
(To:melias)
Ok, steps were as:
1. Enter in IDD mode
2. Select the incorrect surface and delete that selected surface.
3. Create a new surface using boundary blend, before creation I merged two edges (Selected two edges on same side > Merge curves to convert two edges in single)
4. Open Search tool (CTRL +F) and look for Gaps > Click on Find now, result will give you three gaps
5. Move all three gaps to right
6. Select "Close" to fill selected gaps > Finish.
Thank U Sir
ME
